Something to check when you're getting those emission codes
Old Apr 17, 2019 | 06:59 PM
Feedup1's Avatar
Default Something to check when you're getting those emission codes
I was pulling my hair out trying to fix the sensors when I looked to the side of intake manifold and seen some shiny wires but they were old and touching each other. Found out it's a knock sensor so I pulled upper and lower. Remember that you need both gaskets for this. .after the manifold was off I was able to reach the nut. Put new one on. .everything only cost 50 bucks. Started it up and she tries to adjust and will unless you have a computer to clear it for a little while but seemed to fix the problem so remember this and hope it helps you
fordisbest
Jan 5, 2016 04:11 PM
CarletonFord
Aug 14, 2015 07:20 AM
Derrick Calloway
May 15, 2012 10:50 AM
Donald97
Aug 24, 2011 03:29 AM
argneco
Mar 25, 2009 06:04 PM
