2004 driving lights/lamp question
Old Mar 7, 2007 | 01:43 AM
2004FordFreeStar's Avatar
Default 2004 driving lights/lamp question
Hello.
I just purchased a 2004 ford freestar, and I have a few questions:
#1.) Mine was made in Canada or by ford canada. The VIN starts with a 2. Does this have the driving lights? You know the ones that are always on?
#2.) I was looking at the headlight, and noticed a small white bulb in between the headlight and blinker, but it doesn't seem to come on for anything.
That's about it for now. Thanks in advance for your time & help.
Kevin
Old Mar 7, 2007 | 02:31 AM
Default RE: 2004 driving lights/lamp question
Do you mean DRL? Day time running lights...
Is it #6 in the picture?
[IMG]local://upfiles/6756/F04D839369284AC5B4A4C8F068DF9C27.gif[/IMG]
Old Mar 7, 2007 | 12:28 PM
Yes I believe so. I attached a image clearing showing the bulb/light section I'm talking about. Please check this, and let me know. Thanks. I do mean the DRL. How do I turn them on?
Old Mar 7, 2007 | 12:51 PM
That small bulb I mentioned was a marker light..
Here's the DRL info..
IF the SJB (smart junction box) is configured for daytime running lamps (DRL), this feature illuminates the low beam headlamps at a reduced intensity when the following conditions exist:
[*]the ignition switch is in the RUN position[*]the headlamp switch is in the OFF position[*]the autolamps feature has not illuminated the exterior lamps[*]the transmission is in DRIVE[/ul]
Old Mar 7, 2007 | 06:01 PM
My van doesn't have the AUTOLAMP option. So I dont have DRL, right?
The light I pointed out in my image above doesn't light up at all. Any ideas?
Old Mar 7, 2007 | 06:27 PM
goinstrong's Avatar
Could it be the sensor to tell the computer when the running lights should turn on?
Old Mar 7, 2007 | 06:28 PM
goinstrong's Avatar
By the way - he already said there is no other bulb for the system - it just lights your regular low beam headlight automatically and not as bright.
Old Mar 7, 2007 | 08:37 PM
I'm not sure what this bulb does. This is what I'm asking here.
Also I want to know if my van has DRL or not. I was told if it was made in Canada it's standard to have DRL.
Old Mar 7, 2007 | 11:25 PM
Soooooooooooooooooo
If I dont have the AUTOLAMPS option on my headlamp switch I don't have DRL?
Old Mar 8, 2007 | 01:12 AM
Not necessarily..
Autolamps and DRL are two functions which can be configured in the SJB. (smart junction box) The function/requirements for DRL activation would be the same only with no autolamp.. The DRL's are actually the lowbeam headlights with a lower illumination by a pulse voltage.. The small bulb 'looks' like a side marker light..
