2005 Ford Freestar SE Fuel Sensor
Old Jul 28, 2017 | 03:51 AM
samson09's Avatar
Default 2005 Ford Freestar SE Fuel Sensor
I have a problem with my fuel tank sensor. Always shows 0 (no fuel).
Do I have to take off all the fuel tank or is there some access under the seats?
Sorry for my english
Old Jul 28, 2017 | 04:21 AM
It is possible that the fuel module in the tank is faulty, but it might be a good idea to check for a broken wire or poor connection in the circuit between the tank unit and the dash, considering there is a complete loss of signal.
Old Jul 28, 2017 | 05:18 AM
samson09's Avatar
Ok but how to check sensor ? Do I need to take off all the fuel tank or there is some access under the seats?
Old Jul 28, 2017 | 06:56 AM
So we are on the same page,
generally a sensor sends a signal to the computer,
In this case there is a reostat (variable type resistor) , the fuel gauge sending unit, that sends a voltage signal to the fuel gauge in the dash. If that voltage signal is absent usually no reading is displayed. Checking it begins wherever you choose at the tank or the gauge or anywhere in between . It could be possible you might need to drop the tank ,but we always try to check the plugs and wiring/connections before doing that if it can be avoided.
I don't believe there is any access point to the top of the tank without lowering it.
MrMike16
Apr 12, 2025 05:25 PM
Leefoo
Feb 18, 2016 10:43 AM
wisebird
Nov 21, 2014 04:14 AM
amv312
Mar 17, 2013 09:28 PM
TIMLONEY
Aug 13, 2011 04:31 PM
