2005 freestar codes p0401 & c1288
Old Mar 25, 2019 | 09:01 PM
Amanda Renee's Avatar
Default 2005 freestar codes p0401 & c1288
The check engine light came on and these codes were found.
They read as bad break switch and exhaust gas recirculation pressure sensor. Where do I find these parts to replace them?
Old Mar 25, 2019 | 11:33 PM
Use Common Sense's Avatar
The EGR pressure sensor is built into the EGR valve on the Freestar. The C1288 normally pops up for a bad Brake Pressure Switch which is on the front of the brake master cylinder.
Old Mar 26, 2019 | 02:54 PM
Great ok. Now with the Brake Pressure Switch, is it a sensor, switch or transducer?
Old Mar 26, 2019 | 11:23 PM
It's a screw-in Switch. It's a 15 minute job if you drink a cup of coffee. Remove the air cleaner housing and MAF sensor housing/tube for access. The sensor screws into the bottom front of the master cylinder. Just unplug the sensor, Then using an extra long 7/8 open end wrench, unscrew it (a few drops of brake fluid will come out) and screw in a new one. Ford part number is "7F2Z9F924A". It is about $15+ depending on where you purchase it.
Joe Reeves
May 1, 2014 04:12 PM
55_ford_disel
Jul 25, 2013 10:33 PM
ugh3012
Nov 4, 2012 03:40 PM
dadof3girls
Oct 17, 2011 05:28 PM
Bronco76Ranger00
Nov 8, 2009 08:24 PM
