2005 freestar loud A/C fan
Old Sep 10, 2008 | 08:32 AM
Captainkewl's Avatar
Default 2005 freestar loud A/C fan
When I run the A/C every 30 seconds or so what sounds like a fan comes on and makes an extremely loud noise for around 15-20 seconds before it kicks off for another minute or so and then it goes again. Is it normal for these vans to have loud A/C like that??
Thanks.
Old Sep 10, 2008 | 01:54 PM
tomb1269's Avatar
Default RE: 2005 freestar loud A/C fan
There are two electric fans on the radiator for our vans. The second will engage when A/c system tells it to cycle. You could have a probelm with the secondary fan. If you are not sure it is the fan you may want to take a look and listen to the A/C clutch as they also cycle quickly, particularly when the air temp is low and the A/C is not working as hard.
Old Sep 11, 2008 | 07:19 AM
Use Common Sense's Avatar
On my 2004 Freestar, both cooling fansrun on "LOW"mode when the A/C compressor is engaged. Whenmy van is running , but just setting with the A/C engaged as at a long traffic light and the outside temp is 85+, both fans will cycle on and off the "HIGH" mode as additional cooling is required.
While repairing my A/C just recently, both fans were in "HIGH" mode until I got enough R-134a into the system to start seeing liquid in the sight glass on my high pressure line. Once I was seeing almost total liquid, the fans reverted back to the "LOW" mode and normal operation.
You could be getting low on your A/C freon charge.
jhcantwell
Nov 11, 2010 04:41 PM
dria
Jun 1, 2010 11:51 PM
jim333
Apr 7, 2008 07:54 PM
ck
Mar 6, 2008 04:12 PM
ck
Mar 6, 2008 11:47 AM
