Freestar Liftgate Handle Illustrations
Old 02-04-2013, 11:20 PM
Default Freestar Liftgate Handle Illustrations
Liftgate Illustration #1 License plate Housing
http://www.keepandshare.com/doc/5695...-pdf-154k?da=y
Liftgate illustration #2 Liftgate Trim Panel
http://www.keepandshare.com/doc/5695...-pdf-212k?da=y
Liftgate illustration #3 Liftgate Latch
http://www.keepandshare.com/doc/5695...-pdf-236k?da=y
Old 02-17-2013, 02:39 PM
stayathomemom's Avatar
Hi there, I have an 04 freestar and my handle came off too, I subscribed to keep and share to see the pdf files but I may I have your permission to view the files? Thanks for any help
Old 02-17-2013, 07:21 PM
Welcome to the site..
Free to view, hope they help..
Old 02-17-2013, 10:22 PM
Thank you, but when I try clicking on your 3 files, I cannot view them because keepandshare says you have to set the "sharing controls" in your keepandshare account to allow me or anyone else access to view them. I have a keepandshare account as well so I can give you the info you need to allow me permission to view it, or you could email me, probably easiest?
Old 02-18-2013, 12:26 AM
Thumbs up
Thought I had already set for share..Should work now..
These illustrations are to gain access to the handle, not an upgrade or fix. You might try searching the posts, some have had some luck re attaching. If you need help, let us know..
Old 02-18-2013, 03:35 PM
Thanks, hopefully we can reattach the handle as its not broken, I assume it just slid off. I appreciate your help
Old 08-02-2013, 07:31 AM
cablady71's Avatar
my mechanic says he has the part i just haveto make some money 4 it thanks
Old 07-10-2016, 03:08 PM
derekswales's Avatar
Default Rear gate lock is stuck in lock position
How do I open the locking clasp on the rear gate? The handle is unable to open the clasp that closes onto the rear hook located at bottom of trunk.
Old 07-10-2017, 09:49 PM
Bigwoods's Avatar
Where is the buzzer for the lift gate? Sounds like a back up warning. sometimes it takes several tries to get it to shut up. .Wanna remove it.
2004freestarmatt
10-31-2022 08:55 AM
struyker
04-19-2014 04:39 PM
kpostler
07-22-2008 07:37 AM
smokey
07-01-2008 10:52 PM
KREEKVIEW
01-02-2007 10:21 AM
Quick Reply: Freestar Liftgate Handle Illustrations
