A/c problem '04 freestar
Old 05-05-2018, 05:26 PM
rmperrin's Avatar
Default A/c problem '04 freestar
Our 2004 freestar a/c compressor doesn't keep running, it clicks on then off gain over and over. This is after we put the a/c stuff in it and added some leak stop stuff. Any suggestions? Everything blows, just doesn't run long enough to cool the air.
Old 05-07-2018, 03:34 AM
Use Common Sense's Avatar
You could have a leak in the system causing the refrigerant charge to go low. A low charge will cause the compressor to cycle off and on. The best thing to do, would be to evacuate the system, pull a vacuum, see if the system holds the vacuum. If it does, put a full charge of refrigerant back in. DO NOT ADD ANY OIL to the system if you have not lost any. You will liquid lock your compressor and trash it.
Old 05-07-2018, 08:26 AM
rmperrin's Avatar
Thank you.
Old 10-07-2018, 07:58 AM
mtsaz's Avatar
get the system checked. Adding refrigerant will ruin the system because it will be over charged. You most likely have a leak (bad hose) and need a new hose and orifice tube--along with oil and refrigerant. Its the large hose coming off the compressor that goes down along the bottom of the radiator--thats the one that leaks. See if its oily around the places where rubber and metal join---that is a clue---
oldad
10-09-2017 11:56 PM
CantaFord
07-08-2016 07:48 AM
cpanthers100
12-01-2011 09:28 PM
proartwork
08-10-2010 03:47 AM
sefh
05-30-2007 10:32 PM
Quick Reply: A/c problem '04 freestar
