A/c problem '04 freestar
Old May 5, 2018 | 05:26 PM
rmperrin's Avatar
Default A/c problem '04 freestar
Our 2004 freestar a/c compressor doesn't keep running, it clicks on then off gain over and over. This is after we put the a/c stuff in it and added some leak stop stuff. Any suggestions? Everything blows, just doesn't run long enough to cool the air.
Old May 7, 2018 | 03:34 AM
Use Common Sense's Avatar
You could have a leak in the system causing the refrigerant charge to go low. A low charge will cause the compressor to cycle off and on. The best thing to do, would be to evacuate the system, pull a vacuum, see if the system holds the vacuum. If it does, put a full charge of refrigerant back in. DO NOT ADD ANY OIL to the system if you have not lost any. You will liquid lock your compressor and trash it.
Old May 7, 2018 | 08:26 AM
rmperrin's Avatar
Thank you.
Old Oct 7, 2018 | 07:58 AM
mtsaz's Avatar
get the system checked. Adding refrigerant will ruin the system because it will be over charged. You most likely have a leak (bad hose) and need a new hose and orifice tube--along with oil and refrigerant. Its the large hose coming off the compressor that goes down along the bottom of the radiator--thats the one that leaks. See if its oily around the places where rubber and metal join---that is a clue---
oldad
Oct 9, 2017 11:56 PM
CantaFord
Jul 8, 2016 07:48 AM
cpanthers100
Dec 1, 2011 09:28 PM
proartwork
Aug 10, 2010 03:47 AM
sefh
May 30, 2007 10:32 PM
