Ford freestar 05 A/C problem even after filling 134A
Old Jun 27, 2016 | 09:04 PM
  #11
primem's Avatar
the sealant forms solidifies when exposed to air. When a shop connects their equipment to it, the sealant enter the machine and it clogs up the valves in the machine. when they recovery your sealer filled system, it will fill their recovery tank with sealer and now sealer will be passed onto every other vehicle they charge.
now that your leak isn't fixed, the system is full of air, gunk wlll form throughout. when leaking parts are replaced the system will have to be opened and the sealer will again form gunk throughout the system.
Old Jun 28, 2016 | 12:18 PM
  #12
Gulzar Hussain's Avatar
but it is already solidies as you said so how it enter enter the machine and clogs up?
Old Jun 28, 2016 | 11:40 PM
  #13
Use Common Sense's Avatar
The sealer travels thru the system as a liquid looking for leaks to seal. As the sealer reaches any atmospheric air, it solidifies (but only the minute portion that reaches air). The rest continues to flow thru the system with the oil and refrigerant. When a system is evacuated, system oil and the sealer can make its way into the evacuation equipment making it an expensive issue for the shop working on the system with the sealer installed.
Old Jun 29, 2016 | 12:43 AM
  #14
Rahoul Vicky's Avatar
So why I am still loosing the refrigent? The sealent is suppose to seal every small hole. I am confused
Old Jun 29, 2016 | 08:24 AM
  #15
primem's Avatar
because its a junk product. the high side goes over 200psi on the high side...the leak needs to be fixed properly. the leak needs to be located and the bad part replaced.
joshuathomason
Jan 5, 2014 08:52 PM
davidq
Jul 20, 2009 05:12 PM
jrkosik
Mar 5, 2009 06:52 AM
ecx662
Oct 25, 2007 01:11 PM
storm352
Jun 13, 2006 06:14 AM
