Ford freestar fuel problem
Old Jan 12, 2021 | 08:21 AM
Bracsim's Avatar
Default Ford freestar fuel problem
I need some help guys, my 2004 freestar 3.9 keeps blowing the fuel pressure regulator, fuel is coming out of the exhaust pipe, I replaced the fuel pressure regulator 4 times, two Bosch and the last two factory motorCraft and they keep going bad , the scanner is only picking up two codes, one for the front right tire speed sensor, the other one P1000 Protocol code , what can make the fuel pressure regulator to blow up constantly like that.
Old Jan 12, 2021 | 11:21 AM
Excessive fuel pressure could be one.
Suggest you have someone with a good scan tool check what pressure is actually being developed.
Blue0val
Nov 2, 2018 01:06 PM
MossyOak10
May 18, 2015 04:15 AM
raymo46
Apr 29, 2012 07:33 PM
windstar2003
Feb 5, 2012 10:36 PM
kaboom10
Jan 20, 2008 08:55 AM
