Freestar analog dash clock
Old May 2, 2009 | 03:08 AM
  #11
hkenani's Avatar
I would like to ask about the electric cable (harnes wiring) for the clock as I did not find any cable in the dash pot after I remove the a/c vent?
Old Apr 16, 2010 | 04:47 PM
  #12
6d6a6's Avatar
Default Thank You JOE!!!
I had just bought a used 2007 Ford Fusion with the analog clock & the bulb was burnt. I am surprised there is not more information about this online as this was one of the few listings I could find that discussed it & solved my problem. I am out here in Cambridge, Ontario & called up ford to see their price & it was $16.52cdn for a stupid led, my god. But thanks to your research on the similar parts I hit up the nearest VW dealership & they had them for only $3.12cdn so I bought 2 just to be on the safe side!!!
I cannot thank you enough cause now I can actually tell the time at night!!! sad but true!!!
Regards,
Paul
Old Apr 19, 2010 | 03:07 AM
  #13
spolij's Avatar
Default Hi
I have a 2006 Freestar. To get at the clock bulb I removed the glove box on the top of the dash board.
The bulb clip is a little tough to work.
I priced the bulb at ford, $15+ The clock itself probably costs about that. lol
Old Dec 3, 2013 | 12:26 PM
  #14
Bond007ria8's Avatar
Smile Clock removal from Ford Freestar
Originally Posted by jcasaccio
The bulb on my clock has just burned out. To get the clock out of the dash, does it just slide out from the plastic (the whole chrome bezel and clock) or is it hard to remove the clock?
There are actually 4 clips on the bottom of the console which are very hard to get to, what i did was remove the radio, stuck a flashlight in there and pushed the clips in one by one very carefully, they will break if you force them.
Old Jan 30, 2015 | 03:55 PM
  #15
table_4_3's Avatar
Default Thanks jkilpatrick
Just used your detailed instructions on how to remove the clock/vent panel. Worked perfectly!!! Ford now wants $15.50 for the bulb. So, I went with the VW/Audi and the new cost of theirs was $6.03.
Kindest Regards to all that help out on this website.
angelodavid1
Jul 8, 2009 06:32 AM
devoninsatx
Dec 11, 2008 10:59 PM
devoninsatx
JLCAMP
Mar 29, 2008 10:03 AM
tiggergodi
Aug 11, 2007 07:25 PM
