P0301 misfire cylinder 1, plug replacement made worse
Old May 13, 2024 | 01:24 PM
discord's Avatar
Default P0301 misfire cylinder 1, plug replacement made worse
I purchased motorcraft spark plugs with the same gap rating as the plugs in my freestar. Part AGSF42FM. Removing the installed part was AGSF42EGM. I have not been able to find a cross reference part for AGSF42EGM online. The electrode on the spark plug looks larger on the original AGSF42EGM vs AGSF42FM. I also purchased plug wires. I changed only the first cylinder. But I have found that the timing seems all messed up when starting with the new plug. Then I assume that I might need to pick another plug to help resolve my issue. Does anyone know what plug I can purchase that should match the existing AGSF42EGM ?
My thinking has been to swap the misfiring plug / wires first, and then if that does not resolve the issue to change the ignition coil as well.
Old May 13, 2024 | 04:23 PM
discord's Avatar
New plug left vs old plug right. Notice electrode difference
Old May 18, 2024 | 07:01 AM
The plug on the left is supposed to be a longer life plug, Platinum.
Plugs can go bad , but not that often.
Would help if we knew the year and engine in the vehicle.
Mwchestney68$
Mar 28, 2022 03:25 AM
spatterfree
Feb 15, 2016 08:58 PM
marvw
Jan 25, 2011 01:01 PM
Lobstr
Dec 25, 2009 10:13 AM
daveranger
Feb 5, 2008 03:26 PM
