P1744
Ford Freestar 2007, 4,2l 13000 miles
Can anyone explain P1744?
It came with C1730.
The little wrench will start flashing after 30-60 minutes of driving. After turning off the engine and starting it again, it won't flash until another 30-60 minutes.
The transmission doesn't jump when changing gear. If there is a problem there, I don't feel it.
Thanks
It came with C1730.
Thanks
Last edited by Christian Butter Poulin; Jun 21, 2019 at 08:44 AM. Reason: Missing info
I need to put some money on the van. If I have to change the transmission, I'll just scrap it and get another one.
I have that little ODB thing plugged in. I reset the codes while on the highway on the cruise control. The codes reappeared five minutes later. There were no change of gear.
Strange thing, the little wrench will not blink while driving in town, i.e. under 35 mph.
That is when the converter clutch is supposed to lock up around 35 MPH.
Do you notice the trans making the 3 shifts before hitting 30 mph, steady easy throttle it should on straight and level road shift into 3rd before 30 and the converter lock up should feel like 4th gear around 35-37 mph. If the code is valid , you should not get that 4th shift.
