Transaxle on right is spinning, left is not.
Old Apr 8, 2026 | 12:17 AM
Doe's Avatar
Doe
Default Transaxle on right is spinning, left is not.
Heres what’s up… when the car is when the vehicle is running OK and you take it from park and put it into reverse or drive or anything else right the right side of the transaxle is rotating OK where the left side is not OK therefore that probably means that something‘s broken on that right side is that correct? Send a post.
Old Apr 8, 2026 | 03:16 AM
There is a lock nut holding the stub of the outer CV joint splines engaged with the wheel hub assy. Has that come loose or off ?
daddyblaize
Jul 18, 2021 10:24 PM
Grnmstr
Feb 10, 2019 08:17 PM
69BirdWatcher
Dec 4, 2010 11:26 PM
eeguy1953
Jan 11, 2009 01:37 AM
lthacker
Mar 5, 2007 10:59 PM
