Ford Freestyle The new crossover, combining the versatility of an SUV with the compact size and feel of a station wagon.
Starting issue
Old Jun 22, 2019 | 04:05 PM
Skyler Jay Klontz's Avatar
Default Starting issue
I just finished swapping out the motor. I went ahead and did the timing chains while I had it out among a few other common problems and put it all back together. I am chasing down a few check engine light codes for the system running lean but it idles great. Fast forward a bit and if you let the car idle it eventually will die with no warning. And then will not start back. Rapid clicks acting like a starting issue. But if I wait a couple hours. Mind you without charging or touching it. It will start back up just fine. Battery under a load test measured 10.4 and at idle charging with no accessories on at 14.1 if anyone has any ideas for where to start so I'm not throwing money at the problem.
jrube
Apr 1, 2015 02:32 PM
The Fuzz 53
Jan 27, 2009 02:18 PM
oilers1967
Mar 7, 2007 11:44 AM
freez401
Mar 1, 2007 12:06 PM
golferguy
Aug 29, 2006 10:37 AM
