2006 fusion 2.3 egr valve
Old Aug 6, 2019 | 08:22 AM
dannydonx79@gmail.com's Avatar
Default 2006 fusion 2.3 egr valve
Good morning everyone. I was wondering if wnyone can point me in the right direction. where can i find how to change the egr valve on my girls car. Any help will be appreciated. .
Old Aug 6, 2019 | 01:51 PM
Hi Dan,
Before offering any suggestions to help spend your hard earned $$$$ , We always inquire why you need to replace the EGR valve. Many times replacing a part may not be the correct solution. Would you care to bring us up to speed on what is going on?
Old Aug 6, 2019 | 02:52 PM
I was looking to replace the gasket and clean it out. first. But having trouble getting the second bolt out. I read what the book said. we start the car. pluged car in and fired egr codes. Looking to first clean and see if this helps. purchased gasket already. Thanks for helping.
Old Aug 6, 2019 | 04:28 PM
First--------- is the vehicle showing any problems as far as idle etc?
Second,,,,,can you tell us what code you received?
Will not be able to reply right away , have to go to a special meeting.
Old Aug 7, 2019 | 04:26 PM
ys it wants to shut off and p040 i believe is code. autozone plugged in to read codes and gave us a print out.
Old Aug 7, 2019 | 05:01 PM
The code you gave is incomplete, can you check and provide the correct code?
Old Aug 9, 2019 | 08:56 AM
i will. thanks for your help.
Old Aug 10, 2019 | 08:09 AM
Default here is what autozone gave me.
Thanks again. and have a kick *** weekend.
Old Aug 11, 2019 | 08:37 AM
Dan,
I looked at your print out and ,,,,,,,,,,well ,,I don't agree with what they "sold" you.
Might be a good idea if you checked your vehicle's air filter installation and also find out why there are temp codes displayed.
There are reasons for what the air filter is doing affecting engine performance and you might want to do a little more research before spending a lot of time ,effort and $$$ that will not provide a real solution.
ka9j
Jan 18, 2019 12:31 PM
12paddish
Mar 24, 2017 07:44 AM
DJ40
Apr 15, 2015 03:51 PM
rottweiler
May 14, 2008 04:47 PM
chaud
Apr 12, 2006 02:14 PM
