Hood Latch Sensor
Old Dec 13, 2022 | 08:51 AM
Jawsfree's Avatar
Default Hood Latch Sensor
I purchased a salvaged 2019ord fusion and I a missing the sensor connector for the hood latch. This sensor tells the computer if the hood is fully latched or open. Does anyone know if I can just short the two terminals on the end of the wire connector to show the hood is closed? I am guessing it is just a proximity sensor so I was hoping if I shorted it out it would show the circuit closed.
thanks for looking
Jason
Old Dec 13, 2022 | 10:20 AM
That could be how it works, only if you short it to show continuity , you will never know if the hood is not completely latched unless you check.
You might be able to install a typical switch like a dome light switch but it has to show continuity when depressed not like a dome light sw.
drozofilos
Oct 7, 2020 06:48 AM
ptclink
Oct 7, 2009 11:43 PM
cral
Nov 19, 2007 12:38 PM
00spy
Aug 11, 2007 03:03 PM
retread
Sep 8, 2005 05:03 PM
