Passenger door Light
Old Jan 2, 2019 | 04:41 AM
glenpens's Avatar
Default Passenger door Light
I have a Ford Fusion 1.6 Zetec Climate 2006. The front passenger light although the door is shut intermittently the light stays on and I have to bang the door a number of times for the light to go out. I have just notice that if the light on the dash board is on the inside light stays on and if I try to lock the doors they do not lock. Can anyone help me.
Old Jan 2, 2019 | 10:28 AM
Sounds the door ajar switch is hanging up.
You might try spraying the latch liberally with a silicone or graphite based lubricant, lock ease (not WD40 etc) and repeatedly open and shut the door to see if it frees up.
Old Jan 2, 2019 | 10:53 AM
glenpens's Avatar
Did you get my reply. I am not sure I sent it correct.
Glen
Old Jan 2, 2019 | 11:11 AM
Other than the reply above, no...
Old Jan 2, 2019 | 11:23 AM
glenpens's Avatar
I have used WD40 but it was ok for a short time but not sure as the fault is intermittent . I will get some graphite lubrication and try that.
Glen
Old Jan 2, 2019 | 08:42 PM
WD is a water displacement (WD) and will dry out, with little lube properties lasting only a short while.
Any oil/grease based lubes can or tend to attract dirt/debris..
Old Jan 3, 2019 | 02:24 AM
glenpens's Avatar
Thanks for that information I will go and buy what you suggested.
Glen
Old Jan 4, 2019 | 05:51 AM
glenpens's Avatar
Tried Silicon Spray but didn't work so back to the drawing board.
Old Jan 4, 2019 | 10:10 AM
The problem at times, is getting lube actually onto the ajar switch. Many of them were nose up an susceptible to stiction and in a location not easily accessible from the door jamb.
You could try continued applications, or, you could remove the trim panel and try getting some lube in that way.
Or, remove the latch and either replace the switch, proving out it was hanging up, or clean and re apply, recheck ops..
If you want/need to remove the trim panel, latch etc, let me know and I can help with some illustration/diagrams..
Old Jan 5, 2019 | 03:20 PM
glenpens's Avatar
Can you send me some pictures etc for removing the trim.
Thanks
Glen
