2001 clutch problem
Old Apr 5, 2006 | 09:56 PM
vinca48's Avatar
Default 2001 clutch problem
replaced clutch, press plate on 2001 mustang, used my old throw out bearing because new one was plastic and i broke the plastic lip while putting the tranny back in. My problem is the clutch will not catch until the clutch pedal is almost all way out. I know i'm low on trans fluid from the loss while taking trans out, but would this loss cause what i've described? easier to replace fluid if this is the problem than to pull the trans out again. thanks
Old Apr 6, 2006 | 12:23 AM
Duffs302's Avatar
Default RE: 2001 clutch problem
You need to replace the throw out bearing every time you change the clutch. That could be your problem or be a problem.
makuloco2000
Jul 22, 2014 08:33 PM
jmelees
May 17, 2012 02:38 PM
cyberrkatz
Jul 7, 2010 09:46 PM
skid2964
Sep 27, 2009 02:29 PM
2001F150
Mar 10, 2005 12:32 AM
