2003 mustang 4.6l #4 cylindar misfire
Old Mar 28, 2012 | 06:07 PM
E350turbodiesel's Avatar
Default 2003 mustang 4.6l #4 cylindar misfire
this code has been coming up for about a week. I swapped the injectors and coil packs to other cylibndars and #4 keeps coming up. Any ideas?
Old Mar 29, 2012 | 10:03 AM
If you can try making sure you have 12 volts to the #4 injector with the key on. Then switch the meter or test lite and confirm you are getting a ground signal from the PCM when the engine is either cranking or running. If both of those are present then you might remove that side valve cover and look for a broken valve spring on that cylinder. You did check the plug, right?
That should help answer where the problem lies. Let us know what you find, Thanks.
Shipwright
Jun 1, 2013 01:31 PM
umoms
Feb 2, 2013 10:30 AM
tunedin
Aug 11, 2009 06:00 AM
Dundee
Jan 28, 2009 10:35 PM
Goatfarmer
Feb 1, 2008 11:34 AM
