2015 mustang making pop noise
Old Aug 6, 2021 | 10:09 PM
bganska9's Avatar
Default 2015 mustang making pop noise
Hello all, I drive a 2015 v6 manual transmission mustang. Last year, I took a speed bump really hard and broke my half shafts in the back and had to replace the suspension all around. I did opt for a lowering kit in suspension. Since this has been replaced, it started out small and has progressively gotten worse. When I begin accelerating from a stop, it sounds as if my back driver side tire runs over a rock, just a quick pop. It also has begun doing this if I release the gas pedal to slow down, for example for a speed bump, it will make the noise when I begin to press the gas pedal again. Any advice would be appreciated. Nothing seems loose or broken. Thanks in advance
Old Aug 7, 2021 | 06:53 AM
There is something not as tight as it should be.
It will require a very thorough examination to see just what may be loose. It does not have to be dangling loose just not tight.
NikjMiles
Jul 20, 2014 11:17 PM
nmdoc
Jul 11, 2014 03:14 PM
trev0006
Oct 18, 2013 12:19 PM
trev0006
Aug 30, 2013 01:10 PM
trev0006
Aug 19, 2013 06:51 AM
