motor swap
Old Sep 7, 2012 | 08:45 PM
fordmann67's Avatar
Default motor swap
I have a 2000 mustang gt 4.6 just pulled the motor out had a bad knock.Looking at a 95 crown vic with a 4.6 police interceptor will this fit and will my intake go on it.
Old Sep 8, 2012 | 07:08 AM
thexlo8ers's Avatar
IMHO I do not recommend running that engine. Far too many differences. Way too many modifications. All for a 17-18 yr. old engine, no doubt with hard used high mileage, and prolonged idling.
Old Sep 8, 2012 | 11:44 AM
fordmann67's Avatar
Well i won't go that way then.I just found a 2002 mustang short block but it has a romeo motor and six bolt fly wheel. Mine has the windsor motor and an eight bolt fly wheel.Do you think that will fit and can i put my heads and intake on it.Thanks so much for the info.
Old Sep 8, 2012 | 02:23 PM
thexlo8ers's Avatar
Does the clutch disc fit onto the Romeo fly wheel exactly like it does on the Windsor? Like the clutch hub, the part with the damper springs, doesn't hit the fly wheel etc... Does the pressure plate bolt holes, and dow pin(s) match?
What are the numbers stamped on the heads you want to run? With those numbers we should be able to do some research, and cross-reference application.
conanalois
Aug 31, 2013 06:16 AM
midnitev2
Mar 21, 2006 05:37 AM
Zeusfan
Dec 9, 2005 09:34 PM
Deviancekicksin
Jun 3, 2005 05:11 AM
bigbronc
Apr 10, 2005 10:34 PM
