Oil Change Curiosity
Old 10-14-2018, 05:00 PM
lyleb's Avatar
Default Oil Change Curiosity
In the process of doing first oil change on 2017 Mustang GT (5.0). Manual says capacity is 8 qts. I got at most 5 - 5.5 qts.out of the pan when I drained it. No warning lights before. Oil pressure okay. Any ideas? Would the car run 2 - 3 qts. low without giving me some indication? At this point, I'm not sure how much oil to put back in it. Don't want to overfill.
Old 10-14-2018, 06:51 PM
If you go by the engine oil dipstick , you should be OK.
It is possible the engine does require 8qts for addl oil cooling . What does the oil pan appear like, ,does it appear to have a larger type oil pan?
Old 10-14-2018, 07:40 PM
Minnesota456's Avatar
I have a 1990 mustang and it does the same thing. The reason you're only getting 5 quarts is because there is a lot of oil in the filter. Make sure you change the oil filter when doing the oil. My cars dipstick says the oil is way too high when I first put the new oil in but it drops to a normal level once I let the car run and the filter gets full of oil
niallsdexta
01-14-2013 04:17 AM
krktoday
02-24-2011 05:33 PM
Southwind13
03-26-2009 11:49 AM
luckyirishdb
12-25-2007 11:13 AM
dannyf150
02-27-2007 03:50 AM
Quick Reply: Oil Change Curiosity
