water leak
Old Sep 18, 2006 | 10:01 PM
danny88's Avatar
Default water leak
whats up, 88 mustang got a water leak problem, itds leaking water below the windsheild wipers that little cowl thing , whats the easiet way to fix this problem ive been trying for days now, its leaking on both the passanger and drivers side in each corner from inside the car
Old Sep 18, 2006 | 11:18 PM
94 4x4 ranger's Avatar
Default RE: water leak
[sm=welcomesign.gif]Can you take off the cover under the wipers?
Old Sep 24, 2006 | 06:18 PM
danny88's Avatar
yea i took that off but still dont no what to do cause im cant fit the caulk gun in it
Old Sep 24, 2006 | 06:32 PM
If you can see where it is leaking on the inside i would try to seal it there with 100%Sillicone.[hr]If you can find it under the wipers on the outside you might want to get a tube of gasket sealer you should be able to fit that in there or put some on your finger then apply it.
Old Sep 24, 2006 | 06:34 PM
danny88's Avatar
aight thanks ill give it a try
jec65
Oct 20, 2019 08:33 AM
OLDGOAT
Sep 20, 2007 08:30 AM
DAM4
Jul 28, 2007 11:54 AM
kyford
Dec 31, 2006 05:17 PM
mi97tbird
Nov 27, 2005 07:27 PM
