2000 Ranger Loses Power
Old Sep 16, 2006 | 04:48 PM
RJL88's Avatar
Default 2000 Ranger Loses Power
Greetings, I'm hoping someone can point me in the right direction. My 2000 Ranger has the 4.0 auto and lately it has been giving me fits by it's loss of power at random times it will be running fine and for reasons unknown it just loses it's will to continue for a brief period of time and then recovers and runs fine again. It does no good to let up on the gas or floor it, nothing changes. I don't have any fault codes showing up when this happens but I have had a few on occasion that say it had detected lean conditions and one time I got a CO code but I don't recall what the numbers were. My thinking has been maybe the CO sensers were going bad and the goofy thing is trying to compensate somehow. I am also have an issue with it "chirping" in the engine compartment and at time the chirp turns to a nasty and very load squeal briefly and reverting back to the chirping. Anyone care to take a shot at this? Thanks in advance.
Old Sep 16, 2006 | 06:47 PM
94 4x4 ranger's Avatar
Default RE: 2000 Ranger Loses Power
[sm=welcomesign.gif]Sound's like the fuel pump is going out on you.[hr]As for the chirping/squeal it sounds like a bad idler pully.
Old Sep 17, 2006 | 01:58 PM
RJL88's Avatar
Wow I didn't realize how many and much a little fuel pump can set you back. Curious as to why and electric pump is inside the fuel tank though. I don't suppose there is any way of checking an intermittent pump issue is there? As for the chirp/squeal issue there is no problem with the idler pulley and the noise is coming from the rear of the engine area thus making it very difficul to pinpoint. Thanks
Old Sep 17, 2006 | 03:21 PM
You are able to test the pump but it would probly only show up when acting up.[hr]As for the chirp did you check for vacuum leak's?
Original T
Apr 10, 2014 10:51 PM
allenbuilder
Mar 20, 2013 06:42 PM
powerwasherman
Nov 14, 2011 05:14 PM
Rosemary Burt
Oct 5, 2009 08:16 PM
GAMEOVERRACING
Aug 20, 2008 05:47 PM
