93' Hydraulic clutch problem
Old Mar 20, 2014 | 05:47 AM
Cheaptools's Avatar
Default 93' Hydraulic clutch problem
The hydraulic line at slave cylinder will not stay connected. I make the connection,give it a tug and it seems fine,when I press clutch pedal the line pops loose.
The connector looks slightly worn but before I spend the cash on a new line I thought I would ask if anyone knows if this is more of a problem with the slave cylinder malfunctioning.
Could the slave be sticking and causing the line to pop loose?
Any help would be appreciated.
Old Mar 20, 2014 | 10:14 AM
Hydraulic lines can withstand quite a bit of pressure. Suggest you get a new line with a good connector.
Old Mar 20, 2014 | 12:20 PM
Cheaptools's Avatar
Thanks hanky,I feel a bit better spending the money now, from what I have seen on these boards I respect your opinion very much.
Old Mar 20, 2014 | 01:59 PM
Thank you for your confidence. Sometimes I just get lucky !
ford97ranger
Nov 27, 2018 10:38 PM
Etachu
Nov 20, 2013 05:31 AM
Coloradoskier
Jan 4, 2009 03:46 AM
BILL PORCELLI
Nov 1, 2008 11:54 AM
hhhh
Feb 24, 2007 02:20 AM
