95 Ford Ranger
Old Feb 6, 2008 | 07:20 PM
Behzad's Avatar
Default 95 Ford Ranger
Hi all;
My95fordranger has three electrical problem, I don't know if they are related or not.
a) The dome light does not work, light bulb is new so it is not the light bulb.
b) Windshield washer does not work, I conected thepump directly to the battery and it works
so it is not the motor pump.
c) The wiper does work but only on normal speed (position), it does not work on intermitten
nor fast.
I did try an other switch from a newer model (exact same switch) and it did not change any thing. The check engine light is on too but a mechanic checked and said the "auto sensor" has to be replaced so I don't think that is the cause of electrical problem.
Any idea? FORD = FIX OR REPAIR DAILY
Old Mar 8, 2008 | 03:43 PM
grease_monkey1965's Avatar
Default RE: 95 Ford Ranger
did you check the fuses, i have a ranger also and every once in awile i have a fuse problem and things start acting wierd
Old Mar 10, 2008 | 08:56 PM
jellybean69's Avatar
FORD = First On Race Day
b3n129
Sep 20, 2008 05:59 AM
