'99 Ranger 4LT won't start
Old May 14, 2021 | 11:09 AM
GeneT's Avatar
Default '99 Ranger 4LT won't start
It turns over fine. There is fuel in it. I tested for spark at a spark plug. The truck only has 32 K miles on it. What should I try next ?
Old May 15, 2021 | 05:56 PM
How about a little more info ?
When did the engine last run?
If you remove one of the spark plugs , is it wet or dry?
Old May 16, 2021 | 06:57 AM
raski's Avatar
Check fuel pressure. Saying there's fuel in it means nothing if you don't have the proper pressure hitting the fuel injectors. You tested for spark, but what was the result????Your question is very vague.
Old May 17, 2021 | 04:04 PM
GeneT's Avatar
Hanky, It has been about 6 months since it was started. I replaced the 20A for the fuel pump fuse at the fuse box under the hood. I tried to start it; still no luck. I removed one of the plugs and it was dry. Now what ?
Old May 18, 2021 | 11:10 AM
When you turn the key to the on position you should hear the in tank fuel pump run for 1-2 seconds. Do you hear anything from the tank area?
There is fuel in the tank, I hope !
Old May 18, 2021 | 12:14 PM
GeneT's Avatar
Default '99 ranger won't start
I listened for the electric pump sound and did not hear it.
there is gas in the tank
Old May 18, 2021 | 12:31 PM
If you have a copy of the owner's manual, there should be a diagram of the fuses and relays. Look for the relay that is shown as the fuel pump relay. When you first turn the key on do you feel that relay click?
Old May 18, 2021 | 03:49 PM
GeneT's Avatar
Default Fuel pump relay
Yes, I looked in the Owner's manual and found the 20A fuse; I replaced it with a new fuse that I bought at my local Ford dealer. After installing the new fuse, no sound when I turn the key.
Old May 19, 2021 | 05:12 PM
GeneT's Avatar
Default Gas at Shrader Valve
As another test, I put the ignition switch in the ON position and then took the cover off the Shrader valve on the intake manifold. When I pushed in on the valve, then there was gas. Now what should I try ?
Old May 20, 2021 | 01:47 AM
raski's Avatar
Exclamation
Take it to a shop and have it properly diagnosed. You are not getting anywhere. 10 pounds of pressure will squirt out the shrader valve but isn't enough to start the engine. Hang a gauge on it and measure it. We have given you direction but you choose not to follow.
