Buzzing sound
Old Sep 5, 2018 | 04:19 PM
Bridgette Arevalo's Avatar
Default Buzzing sound
Ford Ranger 96, went to get in noticed a buzzing sound and battery gauge was going crazy! Everything else seems fine and once I started truck up gauge went back to normal but still have sound. Any ideas? PS. Battery is new
Old Sep 6, 2018 | 04:55 AM
Depending on where the sound is coming from, it sounds from your description, like a relay attempting to energize and releasing at the same time..
A good part of the time this can be caused by an unintended path of current which is not high enough to completely close the relay or the relay actually leaking current and dropping out, but at a rapid pace.
Sometimes corrosion will allow a poor path for current to flow and result in a problem like this.
What you might try is to use an old standby and remove fuses one at a time and this might help isolate the area when the fuse is pulled the power in that area is removed.
There is always the possibility of a faulty electronic component malfunctioning and removing the power to that component might help pin down the area.
antwon208
Aug 23, 2018 08:27 AM
jbtrapper
Sep 2, 2017 05:14 PM
Cj Hutchinson
Jan 19, 2013 07:37 PM
sonjan
Oct 2, 2009 10:56 AM
Aphotic
Dec 2, 2008 11:20 AM
