A/C not working
Old Apr 29, 2007 | 01:13 PM
gdewitt's Avatar
Default A/C not working
I have a 94 4x4xlt, the blower works fine, heat wonderful but the a/c does not work. i don't hear the compressor clicking, i put freon in does not workcould it be the compressor or condensor?
Old Apr 30, 2007 | 04:05 AM
enibum's Avatar
Default RE: A/C not working
Do you have a blown fuse? It may be a fuse under the hood.
Old May 2, 2007 | 02:17 AM
gdewitt's Avatar
i want to think i checked a few years ago but i will check again. if that is not it could it be a bad compressor?
Old May 2, 2007 | 04:55 AM
91explorer12323's Avatar
Assuming the fuse is good id say the a/c compressor is to blame. when the a/c compressor is functioning properly the a/c compressor will kick off and on as needed. when the a/c system is low on the freon it will kick off and on like crazy till it is refilled to normal range or until it burns the clutch up in the a/c compressor. Which brings me to my next point if it isnt kicking on or off at all with the a/c turned on it may just be the clutch part of the a/c compressor and not the entire compressor that is actually bad but if you are uncertain of the over all condition of the entire unit or if it appears to be a original part then id get the whole a/c compressor assymbly clutch and all.... the only other thing i can tell you is the fuse is good you may want to confirm that you are in fact getting power to the a/c compressor itself,, who knows maybe there is a break in the wiring leading to it and thats why it wont kick on.. good luck hope you get it figured out
Old May 12, 2007 | 07:12 PM
dwight's Avatar
If you found that the compressor is running and you still only have heat look for the blend door being broken. There is an in the vehicle repair on the web to fix that problem. This has been a problem with others.
reynard
Dec 6, 2023 03:25 AM
twoody72
Jul 5, 2009 07:53 PM
flashrulez
Sep 27, 2005 12:53 AM
Sundance
Apr 14, 2005 12:57 AM
