Cam Position Sensor Alignment Procedure
Old Nov 18, 2013 | 01:52 AM
TheWud's Avatar
Default Cam Position Sensor Alignment Procedure
Thought I had a bad CPS, but inspection revealed it was loose enough to rotate. Surely it is off from idea location though truck starts and sounds fine.
All literature seems to focus on R&R, and is based on removing a CPS with a known good install.
It appears the only way to align one that may have rotated due to being loose is to remove and re-install. Is this correct?
Old Nov 18, 2013 | 05:02 PM
There is a special tool to use to do this procedure. Different engines require a different tool. This can be done with a scope , but availability ??
This is also assuming you have a V6 engine. Check wit your local auto supply and they might have the tool. No need to remove if in good condition, just reset.
makuloco2000
Apr 3, 2014 08:55 PM
BASSHAWK
Mar 28, 2012 02:27 PM
holbrom
Apr 2, 2011 08:36 PM
kjellesed
Aug 24, 2009 05:24 PM
justin1980
May 30, 2005 10:28 AM
