Center support Bearing Replacement
Old Sep 21, 2005 | 11:57 PM
roguespirit's Avatar
Default Center support Bearing Replacement
I have a center support bearing going on the drive shaft on a 97 Ranger SC. Is this something that can be done in the garage? How big a deal is it to do yourself?
Old Sep 22, 2005 | 03:57 PM
pakus's Avatar
Default RE: Center support Bearing Replacement
All you need is an air hammer to drive it off with and a piece of exhaust pipe just the right size to drive it back on with.
Old Sep 25, 2005 | 06:13 PM
hockeyhitman69's Avatar
it should be pressed back on and not hammered on but if you dont have access to a press then you have no choice but to hammer it back on
Old Sep 26, 2005 | 01:17 PM
josser's Avatar
recomend you go to the local parts store and borrow the tool, they usually take a small deposit and they refund it back once you return the tools. if you hammer the bearing it it damage it if it goes in wrong!
Old Sep 28, 2005 | 12:45 PM
pakus's Avatar
The piece of pipe that you will use should just fit the inside race. This way it does not touch or damage the bearing. Done a jillion of them and not one has come back, still using the same piece of pipe.
Old Sep 28, 2005 | 07:17 PM
thats good, but it is to find that right piece of pipe and when you have done alot of them it makes it much easier also
makuloco2000
Mar 1, 2016 03:53 PM
makuloco2000
Nov 9, 2014 11:44 PM
Hound
May 13, 2014 08:03 PM
makuloco2000
Feb 23, 2014 10:12 AM
dewdog1978
Mar 10, 2008 06:02 AM
