door ajar light & dome lights stays on
We have a 99 ranger extended cab, 4.0, at, power locks, power windows, 4x4,and the door ajar light on the dash and interior dome light intermitently stayson. Some times the lights work just fine, others the lights stay on for some time. I started to troubleshooting it and was cleaning the front door latches/switches and it seemed as if the lights were working fine. some times the lights went off within 5 seconds other times they went off after 10 seconds. 30 minutes later they started staying on for quite some time. These lights are either on or they are off they don't flicker when your driving. I was looking at a wiring diagram and cannot find the battery saver relay or interior lamp relay or the generic electronic module(gem/central timer module) to start checking them.does any one know where these relays are? or have any idea where else i should check to fix this problem. Thanks
Spray a cleaning solution around the door latch. When you feel it is clean spray in some silicone spray. The door and light switch is in the door latch mechanism and they need to cleaned.
oceanblue_2001
Feb 27, 2010 05:16 PM
Zapman
Feb 16, 2009 06:29 PM
