drive shaft angle
Old Mar 18, 2007 | 12:08 AM
treetopp87's Avatar
Default drive shaft angle
if i put 31s on my truck should i have the drive shaft angle checked?
Old Mar 18, 2007 | 03:06 AM
goinstrong's Avatar
Default RE: drive shaft angle
Not unless you lifted the suspension. (I think I just remembered telling someone that a body lift affects the angle (if so I have to rewrite that) but that doesn't either). The only time you need to check driveshaft angle and more important : length - is when you drop the axles down away from the frame with a suspension lift. If you just put wheels on that are bigger it won't matter unless they hit the fenders and you need to lift it. *UPDATE* - checked the deal in sentence two - I was correct (but worded it funny).
Old Mar 18, 2007 | 03:09 AM
goinstrong's Avatar
Actually, (now that I mention it), you might want to turn your steering all the way to one side and be sure your tires don't rub on your frame in the front end at the back and front of the front tires when it's turned the whole way.
bugy
Dec 29, 2010 05:19 PM
bugy
Dec 29, 2010 01:25 PM
CaptJack101
Mar 12, 2008 12:30 AM
LARGOBRONCO
Aug 23, 2005 10:35 AM
