Engine Getting Hot
Old Jun 25, 2008 | 01:21 PM
pebeinaz's Avatar
Default Engine Getting Hot
Hello Everyone,
Well its HOT now in AZ and most breakdowns happen now
I have a 1999 Ranger with a 3.0L non-flex engine, it is starting to read a high temp on the tempeture gauge when the A/C is on.
I am thinking that its the fan clutch because I was on the freeway at night and the A/C was on and it was getting hot.
If I drive without the A/C on the temp gauge well stay just below the middle all day long but when I turn on the A/C she goes to HIGH, once the A/C is off its back to the middle.
Don't know if thats the fan clutch or the thermostate, ANY IDEALS
Thanks
Old Jun 26, 2008 | 05:55 AM
Use Common Sense's Avatar
Default RE: Engine Getting Hot
Could be fan clutch. Have you ever had the cooling system flushed and "NEW" coolant installed? This can also cause you problems as the radiator/coolant is trying to remove heat from the engines outer extremities on top of the heat that is being removed by the A/C condensor.
jskyrocket
Jul 9, 2013 09:35 AM
jnoel68
May 31, 2010 09:16 PM
SAMF
Apr 30, 2010 12:07 PM
motocrazy8
Feb 25, 2008 12:28 PM
Mgles50117
Jan 7, 2007 03:17 PM
