Horn Problem on a '96 Ranger
Old Feb 19, 2017 | 02:16 PM
ottoman14's Avatar
Default Horn Problem on a '96 Ranger
It worked last year at the inspection but since its stopped. The usual visual ck on the fuses showed nothing broken. I also switched relay's around in the F.Bx un der the hood. Any ideals ?
Old Feb 19, 2017 | 02:31 PM
Because horns generally pull a lot of current there is usually a relay to handle the current to the horn. When the horn button/pad is depresses it makes the ground for the horn relay, which you should be able to hear if the horn is not blowing. If you hear the relay click , sometimes a rap on the horn itself will free it if stuck. If you don't hear the relay work there may be another fuse in the system where you haven't looked yet. Usually the owner's manual will list the fuses and what they protect.
GareOH
Aug 10, 2014 05:42 PM
mrd
Oct 7, 2005 07:44 PM
mrd
Oct 7, 2005 11:43 AM
davidf
Sep 28, 2005 07:10 PM
FuturaCobra
Apr 20, 2004 03:49 AM
