Idling trouble '03 Ranger 4.0 liter
Old Oct 24, 2008 | 09:50 AM
kosloskis's Avatar
Default Idling trouble '03 Ranger 4.0 liter
Got an email from my wifethis morningsaying: The truck was goofy this morning. I started it, but it "kilt" on me twice before putting it in gear.
Had to get to school, so I put in drive and gave a little gas to keep it going, then used neutral when I would have to stop so it wouldn't kill.[/align]
Got to school. Turned it off. Then started it again. It did start, but it is idling funny.[/align][/align]Any help would be appreciated my first thought is Throttle Positioning Sensor. Other ideas would be greatly appreciaciated![/align]
Old Oct 27, 2008 | 11:38 AM
tomb1269's Avatar
Default RE: Idling trouble '03 Ranger 4.0 liter
If it is an auto and will idle in neutral but not in park check IAC (Idle air control) valve, located by the throttle body. Also read any codes from the ECM.
Old Oct 27, 2008 | 03:49 PM
kosloskis's Avatar
Thanks for the replytomb1269
I had my IAC valve changed and it seems to have done the trick. I was hoping to save some money by changing it my self but evey place I called would have to order it. So I dropped $150 for diagnostics,IAC valveand labor (5 min job)
The mechanic said he had changed multiple IAC valves on Rangers due to a plunger in theIACsticking open or shut.
Old Oct 29, 2008 | 12:44 PM
tomb1269's Avatar
Common on alot of the fords, the tell tale is with automatics. It stumbles and stalls in park and idles fine in all other gears. This is due to the fact (as I understand) that when in another gear than park the ECM takes engine speed from the TPS, Park is the only place that the IAC is used. It is different for manual tranys.
jwcarnes
Sep 12, 2013 08:18 AM
bangorme
Oct 16, 2011 07:02 PM
tomb1269
Sep 19, 2007 12:31 PM
MudWarrior
Mar 5, 2006 03:52 PM
