just in case...
Old Mar 12, 2008 | 09:09 AM
mttduley's Avatar
Default just in case...
i re-checked the wires for the spark plugs on my 83 ranger 2.8 v6 and i had wires 2 and 3 crossed at the plugs. when i tried to start it agian in cranked and cranked but wouldn't fire. when it finally tried it made the aweful, almost grinding noise. i didn't try to fire it agian because i was afraid of hurting something. i am aware that i could still have the dstributor in place a 180 degrees off, but does anybody think it could be something else besides timing? i won't be working on it again until saturday, so any responce before then would be greatly appreciated.
Old Mar 13, 2008 | 06:04 AM
Use Common Sense's Avatar
Default RE: just in case...
Why do you still suspect that the distributor is 180 degrees off? If you brought #1 cylinder up to "TDC and READY-TO-FIRE", and verified that the rotor is facing the 11 O'Clock position on the cap and the wire for the #1 cylinder is on that distributor port (see picture in original post), then the distributor in in correctly. Have you verified this?
aintsaword
Nov 17, 2005 12:51 PM
FRANKENSTEIN69
Aug 17, 2005 09:26 PM
FRANKENSTEIN69
Aug 17, 2005 02:51 PM
Tempestv
Jun 9, 2005 02:00 AM
