odometer not working
Old Jun 2, 2008 | 11:06 PM
elitopus's Avatar
Default odometer not working
The odometer in my wifes 1997 ranger doesnt work. It hasnt worked for about 3 years but all the other gauges do. Any idea how to fix this? Truck is 4cyl 5speed
Old Jun 3, 2008 | 06:50 PM
oldtimer35's Avatar
Default RE: odometer not working
If this is an analog type speedo head, which I'm sure it is, you will have to either replace the speedo head or send it to a repair facility to get it fixed. Does the speedo portion work, if not, then you may just be looking at the 2L373 sensor in the differential. Iftheodometer doesn'twork, then the problem is in the head. You can check online for facilities that will do the repair and a quick turnaround on the part. Of course, this means you must remove the cluster, yourself.
Old Jun 6, 2008 | 08:18 PM
elitopus's Avatar
The odometer and trip set dont work, the speedo still does. This means i have to pull the gauge cluster and send it to be repaired? Would it be cheaper to buy another cluster from ebay and swap them out?
reynard
Dec 6, 2023 03:25 AM
newt
Feb 6, 2016 07:53 AM
fordmann67
Oct 11, 2013 08:39 PM
TylerB
Apr 10, 2011 09:18 PM
holden
Oct 3, 2010 07:36 AM
