power window problem
Old Aug 15, 2007 | 05:19 PM
chaka's Avatar
Default power window problem
I can't get my power window to go back up. what could it be ? I have a 2001 Ford Ranger.
Old Aug 16, 2007 | 06:22 AM
Use Common Sense's Avatar
Default RE: power window problem
Could be the wwitch, motor or the window is hung up on the track. Pull the door panel off and see if you can help the window up. Sometimes the lube wears off the track sliders and just needs a little lube job. Vaseline works greatfor this applicationas it doesn't set up like litheum grease does.
Old Aug 20, 2007 | 12:27 PM
tomb1269's Avatar
I have seen several different Fords with corrosion on the switch contacts. Another test is to use the passenger side switch on the drivers side and so on.
robert1958
Jul 29, 2011 07:19 PM
ppeabody
Mar 31, 2008 06:30 PM
Stuntdog56
Oct 29, 2007 01:06 PM
eoreillyfordranger
Jan 10, 2007 02:35 PM
Auburn
Jul 19, 2005 11:19 PM
