trans light flashing
Old Aug 5, 2007 | 08:47 PM
rangerII's Avatar
Default trans light flashing
I can't figure it out. The trans in my 2003 4x2 ranger will go into "safe mode", I guess,usually when I first leave my house. It happened more frequently during the colder weather, but will do it once in awhile still. I usually can fix this by restarting the engine and it won't act up for the rest of the day. The truck has a 2.3L with 24K on it as well as the tranny. I did a motor/ tranny swap into a higher milage truck,123k, from a wrecked, salvage truck. One thing bothers me real bad, it seems to wind too long after you pass another car and when the engine rpm's come down it will upshift. I don't think it should do this. I have changed the fluid and filter to no avail.Also, it seems to go into gear with some hesitation hot or cold. It has remained in 2nd at a stop light 2 times which I'm uncomfortable with. It always seems mushy shifting.I really need some input to correct this,
Thanks to all
Old Aug 20, 2007 | 12:46 PM
tomb1269's Avatar
Default RE: trans light flashing
When you did the swap into the truck did you take the computer?
Old Sep 4, 2007 | 09:06 PM
rangerII's Avatar
I tried to use the computer from the salvage truck but the coded ignition key would not sync with it. You are referring to the computer in the cowl correct. I had the codes removed once before.The only thing it did however is kick the theft light on in the dash.
Old Sep 5, 2007 | 01:32 PM
tomb1269's Avatar
There are some sensors that may be prt of the problem that only thenewer computer will deal with. I think one is the VSS. I am not quite sure what it does.
tomcat5
Aug 10, 2021 05:10 PM
italianjeremy
Mar 3, 2006 10:59 PM
Cactus
May 24, 2005 12:59 PM
ajrn
Apr 12, 2005 05:16 AM
