Ford Sport Trac SUV seating and versatility meets the compact pickup truck in this crossover.
2002 Power rear window not working
Old Oct 2, 2020 | 04:52 PM
Sue_P's Avatar
Default 2002 Power rear window not working
The rear window stopped working - checked the fuse and that is still good. Any ideas what else I should check?
Old Oct 2, 2020 | 07:17 PM
scott.butler4's Avatar
Is this a rear defrost issue or a rear adjustment issue?
Old Oct 2, 2020 | 07:59 PM
Sue_P's Avatar
Default Thanks for your reply
There is not a rear defrost on it and not sure about the rear adjustment - it just stopped working. Came home, put the window down and nothing now.
Old Oct 2, 2020 | 08:15 PM
Do you hear any noise when you move the switch either way?
Old Oct 2, 2020 | 09:59 PM
Sue_P's Avatar
No noise at all.
Old Oct 2, 2020 | 10:21 PM
Ok so here is the wiring diagram, connector view for the rear window, and rear window switch bench testing.
You should first check both the highlighted fuses.
Disconnect the rear window motor switch C351, turn key to on, test if there is continuity to the positive battery post at pins 2 and 7, test if there is continuity to the negative battery post at pins 5 and 8.
You can use the wiring diagram and the connector view to test if the switch(red arrow) supplies a ground to the correct pins of the motor connector(blue arrow) when the switch is used through its positions.
Next remove the rear window switch and bench test it using the directions of the last picture, also test if there is continuity to the negative battery post at pins 6 & 8.
loomisgang
Feb 16, 2015 08:42 PM
Frustrated Ford Owner
Sep 16, 2009 07:46 PM
bthomas70
Sep 14, 2009 07:41 PM
crimey617
Aug 13, 2007 10:38 AM
hilliad
Oct 16, 2006 02:35 PM
