Ford Sport Trac SUV seating and versatility meets the compact pickup truck in this crossover.
2005 SportTrac with a headlight switch issue...
Old Jul 9, 2022 | 05:22 PM
TimmerDog's Avatar
Default 2005 SportTrac with a headlight switch issue...
Hi there everyone,
The truck has the switch with Auto, Off, Parking, Headlights, Foglights and dimmer control. Has worked great for years by just being on the Automatic setting. Unfortunately, now the switch must be manually operated because when on Auto, it ALWAYS blows the 25A fuse under the hood.
Is there a way to test the switch to see if it needs replacing or could this be a simple relay issue?
Looking Ford-ward to hearing from You!
TimmerDog
Old Jul 13, 2022 | 12:13 PM
As you know whenever a fuse blows there is some reason for excessive current being drawn in that circuit.
Without actually checking the wiring and components with a meter , OR a thorough physical examination of associated wiring , it could be anything. Most times a wire carrying power to a component gets chaffed and now we have a short path to ground ,which is not right. It would be unusual for the switch to cause this , but not impossible.
Old Jul 13, 2022 | 05:51 PM
raski's Avatar
It's not likely a switch or relay causing the fuse to blow. They likely would cause an open or inoperative circuit, not a short to ground. As mentioned, damaged wiring causing a short to ground or the lighting control module.
Old Jul 13, 2022 | 07:53 PM
TimmerDog's Avatar
Default Headlight issue...
Thank you Hanky and Raski
Thanks for your input to my issue. This all began when we purchased our travel trailer and the dealer installed the brake control. That caused the wiring harness to fry a bit. They repaired the harness but that's when the auto light issue began. So we taped the word NO on a piece of masking tape and went back to manual switch use. I'll continue to tinker with it and hopefully, will be able to fix it.
Again my thanks to you,
TimmerDog
Old Jul 14, 2022 | 03:19 AM
raski's Avatar
It always helps when ALL relevent information is listed in your post.If this all started with the trailor wiring addition (I am not going to call it an upgrade), I would take it back the the installing dealer to have the system checked.
Paul Clayton Thomas
Mar 22, 2015 01:57 PM
pythonwill
Jun 11, 2013 08:42 AM
Rusty Baker
May 25, 2013 01:51 PM
Comcast Tim
Mar 26, 2008 07:06 PM
broncocarnage
Dec 11, 2007 12:07 PM
