Ford Sport Trac SUV seating and versatility meets the compact pickup truck in this crossover.
Ford Spt Trac issue
Old Jul 9, 2017 | 02:30 PM
gepetto's Avatar
Default Ford Spt Trac issue
Here is one I hope u people can help me with. I have owned this 2002 Sport Trac since new and have had a intermittent problem from the beginning. The car has 147.000 miles on it and every so often it will have no power as if its running on 2 cylinders if i'm on the road when this happens if I try to give it gas it noses down and I have to run at about 40 MPH no more the that and it dies. Here is the oddest thing if I pull over and shut down even for only a few minutes start up again it runs well ( until next time, could be 5000 miles or 100 miles. I have cleaned ALL the intake ports and changed the coil, had the cat tested the fuel pump checked, all the obvious suspects. I don't get a "check engine light" no error codes appear, can't figure it out. HELP
Old Jul 22, 2017 | 02:05 PM
bossmav's Avatar
You have a computer issue, this will happen and drive you crazy. Mine does it every once in a while and all that is needed is a restart. Cut the truck off let it sit for a moment and it should reset it's self. If not might be time for a new brain. Good luck!
Old Jul 23, 2017 | 12:37 PM
gepetto's Avatar
thanks that is exactly what i do and have done since the veh was new u just NEVER know when it is going to occur I have priced a new comp and it not bad $ 229 pre programed with new keys from a outfit right here on Long Island. Thank you for the reply
Towguy76
May 22, 2013 12:01 PM
only1bigdaddyo
Apr 28, 2013 06:26 PM
murray46
Sep 30, 2012 09:47 PM
MooTony1994
Jan 2, 2006 12:07 PM
RHenry
Jul 13, 2005 01:11 PM
