Ford Sport Trac SUV seating and versatility meets the compact pickup truck in this crossover.
PO451 2007 Sport Trac
Old May 2, 2021 | 09:34 AM
rflores933@hotmail.com's Avatar
Default PO451 2007 Sport Trac
The car was running without error codes. Replaced the fuel pump as records showed it hadn't been replaced. Then PO451 started appearing. Had the shop replace the evap hose and fuel tank pressure sensor (FTP), cannister vent valve and passed a smoke test. Cannister purge valve which releases captured fuel to the intake was checked and working properly. The mechanic indicates that the fuel tank pressure sensor reads 4.7" Hg (with the gas cap off I believe) which apparently is too high. Research indicates the PCM may have to be reprogrammed to reset the offset calibration of the FTP? Any ideas would be appreciated. Thanks.
Old May 2, 2021 | 09:36 AM
Default FTP replaced twice
The FTP is a dealer part and the mechanic returned the first one and got the same problem with the second FTP. So its not the FTP.
Old May 7, 2021 | 06:58 AM
Default Ford Dealer diagnosis
The Dealer indicates that the wiring harness should have been replaced when the fuel pressure sensor was replaced. Now I have to pay to have the fuel tank removed again but hopefully, this will fix the problem.
CharlotteQ
Feb 8, 2021 08:42 AM
BarbiT
Nov 9, 2015 10:53 AM
susansherb37
Feb 3, 2013 11:42 AM
SportTrac03
Jul 23, 2009 05:11 AM
yeahmen
Dec 14, 2007 11:32 AM
