02 Taurus - Loss of Power
Old Jul 2, 2012 | 05:58 PM
gale.bluntschly's Avatar
Default 02 Taurus - Loss of Power
The check engine light is on P01132 and P01152. I have replace the plugs, wires, fuel filter and pvc valve. When I hit the gas it drive fine until I get to about 30 mph them it doesn't want to go any faster and the rpms only get higher while sucking down gas. I have had the rear cat checked and it is not clogged.
Old Jul 2, 2012 | 07:06 PM
The engine appears to be running very rich.
Were the plugs all very black when you removed them?
If that is the case, chances are the converter has been overheated and possibly damaged. How was the cat converter checked?
The codes are involving both upstream O2 sensors.
All this may be the result, of a different problem.
Old Jul 3, 2012 | 07:28 PM
Only the rear converter was checked and it was clear. How can I check the front one?
Old Jul 3, 2012 | 07:34 PM
On the plugs. I had them done so I didn't see them.
There is an tube on the EGR and it has a stem coming off it and whistles especially when I hit the gas.
Old Jul 3, 2012 | 08:02 PM
This is what I think is happening & I could be wrong.
The whistle you are hearing is a vacuum leak, the computer is trying to compensate for it and in the meantime the engine is getting too much fuel and the oxygen sensors are indicating that.
I believe if you correct the source of the leak, the whistle, everything should be OK.
You will have to give the computer time , a few trips, to relearn the new settings after the leak is corrected.
Let's hope you don't have an exhaust restriction.
Joseph Ayers
Jun 19, 2013 01:50 PM
jpdelia
Nov 12, 2006 09:40 AM
mthoenes
Feb 22, 2006 09:51 PM
ken441959
Canada, Over Seas & Elsewhere
Jan 23, 2006 07:01 PM
93blackranger
Jul 2, 2005 11:53 PM
