1996 Ford Taurus
Old Oct 23, 2012 | 07:08 PM
mrcolabearyahoo.com's Avatar
Angry 1996 Ford Taurus
I have a 96 Ford Taurus, If you turn the key to start it there is nothing, the battery is new, I have replaced the ignition switch as well as the ignition cylinder, and the starter, and still nothing. If you remove the key from the ignition you can still operate the windows as well as the radio. Any help reguarding this will be greatly appreciated.
Old Oct 24, 2012 | 03:52 AM
Have you tried adjusting the position of the newly installed ign switch ?
Old Oct 24, 2012 | 07:00 PM
I have tried different positions with the new ignition swith. I have just also replaced the ignition coil and still nothing. When I try to turn it over I still get nothing not even a click click. You can still ploay the radio and power the the windows without the keys in it.
Old Oct 24, 2012 | 08:29 PM
bandit1948's Avatar
it might be the solenoid not kicking the starter in ! are the battery terminals clean and tight ?
Old Oct 25, 2012 | 06:14 AM
the trminals are clean and tight ... just can't figure out why power is still going into the car after the key is removed ..... I will have to remove the starter and try testing it to see if the selinoid is kicking in
Old Oct 25, 2012 | 10:57 AM
Does the vehicle have any type security system on it? If not , I would suspect a problem with the GEM module. It controls most of the body functions and accessories.
Old Oct 25, 2012 | 09:16 PM
greasemark's Avatar
Ok, does anything inside the car come on like it should? like the dome lights or dash?
Old Dec 17, 2012 | 01:53 PM
JackC's Avatar
It has been some time now.
How did Mr. Colabearyahoo make out wiht this problem?
fw31100
Sep 22, 2008 08:06 AM
fw31100
Sep 21, 2008 08:13 PM
Hellhound21
Jul 19, 2008 12:03 AM
jdmdc2pusha
Nov 4, 2007 05:31 PM
VinnieZ
Apr 19, 2007 06:46 PM
