1997 ford taurus auto. Transaxle fluid drain of 12.2 qts.
Old Oct 8, 2012 | 01:27 PM
1960nick's Avatar
Arrow 1997 ford taurus auto. Transaxle fluid drain of 12.2 qts.
How can i drain 12.2 qts. Of automatic transaxle fluid from a 1997 ford taurus transaxle and replace the filter ?
Old Oct 8, 2012 | 01:41 PM
1960nick's Avatar
Thank you for help,
*** 1960nick
Old Oct 8, 2012 | 02:19 PM
If you removed the trans and disassembled it and drained the converter you could get close to 12+ quarts, but if you are planning to just change the filter and the fluid that comes out when dropping the trans pan you will only get about 4-6 quarts.
They might claim to get 12 qts with a trans flush, but that would be like opening Pandora's box because the age and mileage , in my opinion, (IMO) would be looking for problems.
Old Oct 8, 2012 | 06:03 PM
1960nick's Avatar
Dear hanky,
The color of my trans. Fluid is light brown and does not smell burnt. The consistency of the fluid is the same as new red fluid. When the temp. Of eng. Go's under the half way mark on the temp. Gauge and stays there the trans. Starts sliping going into the upper gears. Would it be ok to just drain the the pan, replace the filter and put in 32 oz. of Rislone Trans. Stop Slip with Leak Repair also 4 or 5 qts. of new fluid with the old light brown fluid ?
Would doing this be a good fix for the trans. Operation and stop the sliping ?
***** thank your help and quick reply,
***** 1960nick
Old Oct 8, 2012 | 06:40 PM
I t might help temporarily, but I think there is an underlying problem that should be diagnosed by an experienced shop. There are several reasons for the trans to slip in the upper gears and to try to answer your questions would not be a good idea without additional tests.
Old Oct 8, 2012 | 09:18 PM
1960nick's Avatar
Thank you again for your help,
***** 1960nick
jtl4
Sep 19, 2010 12:25 PM
Beckys 03
Aug 29, 2008 03:21 PM
JoeMechanic
Apr 23, 2008 02:52 PM
Don7887
Jan 24, 2008 06:52 PM
thomarw
Dec 16, 2005 07:40 PM
