2003 Taurus Windshield fluid problem
Old Mar 7, 2007 | 05:26 PM
arbutler's Avatar
Default 2003 Taurus Windshield fluid problem
The windshield washer fluid on our 2003 Ford Taurus will only shoot out a few inches. Both sides. The windshield washer motor runs but it will notshoot out enoughto make it to the windshield. The washer tank is full of fluidbut it doesn't make a difference. It's not frozen. What can we do?
Old Mar 7, 2007 | 05:43 PM
dukesport's Avatar
Default RE: 2003 Taurus Windshield fluid problem
Its either a clog in the fluid lineat some point, trash in the bottom of the tank, or a defective pump motor.
1.For the lines, you can shoot forced air through them for clearing.
2.For the tank, if filled, most likely, you would need to remove and slowlyempty it for signs of trash at the bottom.
If the above two doesn't do the trick....then its a good bet that the pump motor needs replacing.
Old Mar 9, 2007 | 11:51 AM
jjcast13's Avatar
Make sure the hose is not clogged in the fluid resevoir. Make sure that there are no kinks in the hoses. Check that the hoses are not clogged. Check that the outlet is not clogged.Use a straight pin in the holes to remove any blockage
msting
Apr 15, 2022 05:10 PM
1960nick
Mar 4, 2018 08:58 PM
bronco nut
Oct 7, 2010 08:14 AM
vivalasvegas777
Apr 19, 2009 06:09 PM
tolobill
Feb 13, 2007 01:17 PM
