2010 Taurus SEL TPS Module Location
Old Nov 27, 2024 | 06:56 AM
ljpet's Avatar
Default 2010 Taurus SEL TPS Module Location
Hi everybody hope all is getting ready for a great Thanksgiving. Does anyone know where the TPS module is located? The local Ford dealership tells me it's behind the right front kick panel. Other information I got was it's under the floor console. Hope someone can help me. Thank you
Old Nov 27, 2024 | 12:33 PM
I think you might have something not quite clear, never came across anything called TPS module..
Old Nov 27, 2024 | 12:43 PM
ljpet's Avatar
I think the tire pressure sensors that are in the tires sends signals to a modual that shows when the tires are low on air. I was told that the location may be in the right front floor kick panel or in the middle floor console. Has anyone heard of such a modual?
Old Nov 28, 2024 | 09:35 AM
Yes there is a TPS System monitor in the PCM.
Some systems use tire rotational speed to judge unequal tire pressures.
Special tool is required to program so PCM knows which tire is where and watches for pressure difference.
Old Nov 28, 2024 | 07:36 PM
ljpet's Avatar
Thanks again hanky
ljpet
Oct 24, 2024 08:55 AM
dtongay
Jan 24, 2023 02:13 PM
bradkorn
Oct 18, 2011 03:04 PM
techmanbd
Apr 11, 2008 07:18 PM
stanshepp
May 12, 2006 04:29 PM
